air cleaner bracket
air cleaner bracket
I am seeking an air cleaner bracket for my 66. Part number is C23088. Please PM me. Thanks.
Re: air cleaner bracket
What is your location Jerry?
If you could add it to your details it might help one of us locating the item for you. I am in the UK and have several contacts for second hand parts and I know of a couple of members who might be able to help in the US.
Thanks for pointing that out. I joined and registered my car shortly after I got it several years ago and was active-ish at the time. I had the car info and all set up then too, But then I forgot my user name and apparently now I have started all over as a different user. Its just as well, that guy was a flake anyway. I am in Indiana at the southern tip of Lake Michigan.
Did you ever find your bracket? Here's one on ebay. https://www.ebay.com/itm/125687896786
I didnt, and had subsequently decided I should just make one.... but of course I havent yet.. Hmmmm Thank you for the lead.
I finally made my own out of some bits of flat steel stock. so, parts "found", thanks for looking.
Fitting that bracket requires loosening and removing some headbolts which always makes me a bit nervous that the head gasket will be impacted.
Last 100 Members Who Visited This Topic. Total 52 visits
John Quilter (7),
cass3958 (7),
jerry_hoback (12),
awiedie (7),
member (1),
Jose (1),
RollyTG (4),
gripper (1),
philippe (2),
David Reilly (2),
badger (2),
Treetrimmer (2),
JCS (1)
