3D printing velocity stacks ..
As an experiment I am printing velocity stacks for my HD6 SUs.
Experimenting with dimples to affect the flow..
Flange width : 2.75”
Carb side 1 1/2”
Horn length 5 1/4”
I have metal mesh filters.
No idea as to how to honestly measure the difference in the stock plum/cleaner setup.
Pictures are of an older version..flange upside down, and smooth horn.
Pictures of the correct flange and dimples on the inside of the horn coming.
Carb side 1 1/2”
Horn length 5 1/4”
- 16E4F7B5-480C-428F-8E58-189B34149D81.jpeg (3.17 MiB) Viewed 4826 times
- 4B0CFCD2-684E-4D4F-A6DE-5874C3CC4DA2.jpeg (3.31 MiB) Viewed 4826 times
- 891AFCBE-F282-4C93-A421-00EDEF143B90.jpeg (3.09 MiB) Viewed 4826 times
1964 S Type, 4spd, OD
1988 M6, 5spd
1988 M6, 5spd
Re: 3D printing velocity stacks ..
Resin is good up to 350F.
1988 M6, 5spd
1988 M6, 5spd
file:///var/mobile/Library/SMS/Attachments/61/01/CE6E7A75-76FB-4396-BB5F-C43CED5BA271/IMG_9111.MOV
A video of the post prep .
1988 M6, 5spd
1988 M6, 5spd
Final prototype..
Correct flange
Dimples for flow.
Will paint outside surface gray aluminum
Metal mesh screens on order.
Correct flange
Dimples for flow.
- FFEEDE79-99DA-4EF1-B5F5-6E0ABDDC58DD.jpeg (3.07 MiB) Viewed 4811 times
- 42669214-64FA-429E-9712-C192D46B25C9.jpeg (2.95 MiB) Viewed 4811 times
1988 M6, 5spd
1988 M6, 5spd
Here is a flow simulation .gif from Solidworks.
- C42ECEE3-7DED-439C-B9F3-2D5D22D6507C.gif (9.42 MiB) Viewed 4808 times
1988 M6, 5spd
1988 M6, 5spd
I need to run the simulation with th3 dimples.
1988 M6, 5spd
1988 M6, 5spd
Solidworks shows the effect of the bend is significant. The bend is is less of a degree than the stock plenum. I will look at what a 1 1/2” straight stack flow looks like. Their are advantages to a taller stack .. a positive effect on top end performance.
1988 M6, 5spd
1988 M6, 5spd
Thats very interesting. What do the filter screens look like?
- DD99D435-2268-443E-AD79-D516D9AF0D52.jpeg (62.67 KiB) Viewed 4787 times
1988 M6, 5spd
1988 M6, 5spd
1st model is horn with smooth sides. More turbulence and has areas of high flows
2nd model is horn with dimples. Uniform flow over a greater area in the carb inlet.
- 455F42DD-7B46-45A0-A9C0-E79467137392.jpeg (47.72 KiB) Viewed 4786 times
- 3D1F0B32-7B45-4533-8521-FB39A4799F23.gif (9.74 MiB) Viewed 4786 times
1988 M6, 5spd
1988 M6, 5spd
Last 100 Members Who Visited This Topic. Total 162 visits
cass3958 (18),
Norton (3),
jaguar&mg (2),
minimeadow (16),
Treetrimmer (16),
John Quilter (15),
Rogerisleofman (11),
NigelW (5),
Bingo (47),
Glyn Ruck (22),
Robbo911 (3),
jerry_hoback (2)
