- Do you feel a real difference between 3.4 and 3.8L ? Only 10SAE HP between, but I saw the curves here, the power and torque is on lower RPM on a 3.8L, so really the best choice ?
- I can’t find somewhere the different colors existing, exterior and trims, is it registered somewhere ? I didn’t found it in the brochures.
- I heard that adding a power steering to a not powered one is not so easy as that, because it affected the heating of the interior because it steals room to the heater jacket ?
- Model years to avoid ?
- Are the spoked wheels easy to find if not equipped with ? Same question for finding a sport 3-spoke flywheel (seen in MKII and “S”).
- As common for the US, models from there have another compression Ratio ? Who affected the power ?
- Can you list me the points I have to look carefully for choosing my “S” ?
I already noticed: Oil pressure when hot. Engine noise (Upper or lower “ticks”). Mileage of the engine. Rust on all the wheel arches. Status of the paint, Trim, Wood, chromes, electrical equipment’s, roof, door alignments.
Thanks a lot for your help (I hope !), I guess this is the best place on earth to talk about the “S”
